The crossover was put just inside the door frame itself. Not sure how much room is behind there on a 33, but the was no room under the door trim to fit it. Wasn't too fidly, you only have to put it there once. A mate of mine did this all for me. I trust what he is doing as he won the IASCA sound quality competion in his novice class in 2000.
Guest GR33DyMANGO
u can fit ANYTHING with the use of a trusty angle grinder.. just be careful when using it:)
then just remake the parcel shelf with a sheet of mdf wood.
all u need to do is take out the old shelf, angle grind away. take the old shelf and use it as a template for the new shelf, cover the new shelf with carpet (using something like pva glue to stick it on) and oh yer drill the holes before putting the carpet on.. insert shelf... put in speakers and hey presto!
