Perhaps you have a blocked cat and this is what the sensor is telling you?
Wouldnt expect it to just all of a sudden block and cause the car not to start at all.
The sensor just unscrews from the cat. Mine still works (AFAIK anyway)
The sensor only makes the warning light come on on the dash, it doesn't send any signal to the ECU.
I changed my fried cat and couldn't get the sensor out so I just cut it and blocked the hole in the new cat with a bolt.
The light comes on and goes out when the car is started.
Your cat may be blocked, or your not starting problem could be totally unrelated...
Try removing the cat and starting the car, if it starts, smash the guts out of your cat, reinstall and buy a new cat ASAP.
Same problem with my car .
My car runs and drives fine tho,but the car wont idle for more than 5mins even after a drive and the owner told me the cat temp is not plugged in thats why its causing it to automatically shutdown or theres more to it than that? & the temp light is always on.
any help would be great.
Yes that's my understanding of the R33 too.
In an R32 the cat over temp light is the check engine light so it does connect to the ecu for that purpose.
Can't understand people hacking wires.
Under the passenger seat you can UNPLUG the cat sensor wiring, no need for butchery.
Fit a grommet in the floor pan hole and it's looking good.
Well mods on the
-Full 3" exhaust
-Fuel pump
-pod filter
-TS boost T
stock everything.
idles fine n drives n sounds fine! But if i start the car let it idle it just won't idle for longer than 5mins its the same even after a drive it automatically turns off the car
But all electronics are on all i have to do is turn the key to the right n it starts again fine.
Try hard wiring the fuel pump using the 'how to', most aftermarket pumps don't like the low power supplied by the factory fuel pump controller. To test it you could run a temporary wire to the battery...
What pump did you install?
well this morning i started up to see how long it will run for
it ran for 12mins n could of kept going so believe it or not it didnt happen today
when i came back from work,it usually runs for a bit n shuts down this time it ran for a while till i got bored like wtf :closedeyes:
i bought the car with the fuel pump already installed.the last owner put it in and he said it holds up to 600hp i believe
Brand- no idea
i'll ask for details coz he said he would fix the shutting down problem anyway.
since he said its cat being unplugged,now i know its not im not happpy :verymad:
Reset the ECU. Quick to do and sometimes solves the problems.
Disconnect battery (negative terminal), Hold foot on brakes, flick lights on and off etc, basically just do whatever you can to drain any residual power.
Wait for 10 mins or so then plug the battery back in and start the car, go for a drive etc.
I'm not sure if the 10 mins of sitting is necessary but just to be sure
