I am coming down to the nitty gritty part of this build. I have just about finished the dry sump RB26 oil pan. But, I have a question for all you RB30 guys......
Would it be beneficial in adding the RB26 girdle windage trays to the RB30 girdle? Has anyone done this? Would this be a bad thing or not?. I'm thinking that with the RB26 oil pan bolted to the RB30 block, the windage properties would be nearly the same as the RB26. So I thought about drilling and tapping the RB30 girdle for the trays.
What do you guys think?
Is it as important seing you're running dry sump? Won't be anywhere near as much oil in the sump obviously.
Certainly can't hurt though, might help the oil get back to the pickup point quicker.
Shouldn't be too hard to do. Might just need to drill a few new holes and possibly space the tray to the girdle in a few spots if it doesn't sit flat at the mounting points.
Ive done it on my RB30 girdle, not hard to do, mark the position of the holes, drill and then tap the threads into the girdle, im surprised more people dont take advantage of the wind-age trays.
  • 1 year later...
how is this holding up?
My engine machinist didn't want to do it.
So, I started (front tray on).
Speaking to a colleague who said it can weaken the girdle.
Just after some piece of mind.
Although, it's kind of too late to turn back now.
In my opinion no ways there is enough load put on the girdle to cause any problems. All the linking sections of the girdle does is prevents fore and aft movement. A few 6mm holes are gunna do f'all to affect that.
It ties the bottom end main caps together exactly in the same way as the drilled factory RB26 one does, no weaker, no reported cracks of failures what so ever.
The rails only take fore and aft stress to tie the caps together.
A pic where you can see part of mine done....
IMG 1515
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
