i have an 88’ r31 thats on duel fuel and recently when i change over to petrol the car wont get out of first gear and limits at 2000rpm on gas the car runs like a dream. i don’t think its an injector coz’ its not missing maybe it’s fuel starvation? fuel pump is kinda loud and changed the fuel filter not long ago its got me really stumped.
https://www.sau.com.au/forums/topic/427928-ecu-limiter-turning-on-at-2000rpm/
If your AFM looks good, check it with a multimeter at the plug. You should have:
Black/White - 12V
Black/Silver Tag - Ground
White - Ground
Black - This is your Signal wire to the ECU, check the continuity of it back to Pin 27 on the ECU.
If you read the post right above yours in General Maintenance, I was having the exact same issue, not with switching over to petrol, but running it all the time. I even have a video showing my 2000 RPM limit. I have a list of everything I switched over trying to fix the issue, but what it ended up being was my AFM Signal wire was grounding out with one of my grounding wires in the protective sleeve they have going back to the loom. A Continuity check found this, and I bypassed the fried wire for the signal straight to the ECU. Runs like a dream now. No signal from the MAF causes your ECU to run in Limp mode, I'd imagine, which limits it out at 2000 RPM for the engine's safety.
Good luck to you!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
