Good day SAU forum go-ers!
My names Drew, a new BNR32 owner from Brisbane. I brought the car a few weeks ago with the following done:
Eagle Rods
CP Pistons
Metal head gasket
Tomei 272 degree cams
Tomei cam gears
Springs/retainers
HKS turbos
Apexi PowerFC with hand controller
Intercooler
Nismo strut brace
GReddy BOV
The car puts out a tad over 400hp at the wheels @ 18psi.
Since then i've lined up a few bits and peices including a Kaaz 1.5 way diff, Cusco swaybars, Ikeya control arms and BC coilovers.
My next main hurdle is to get rid of the horrible "GMAX" wheels and replace with something a bit easier on the eyes! As well as new exhaust, re-tune and other touches.
I've joined the forum to browse the classifieds and spend hours reading the (seemingly vast and knowledgeable) technical sections.
So far my weeks of GTR ownership have been very pleasurable, i can't wait to iron out the small creases and enjoy the car for what it is, a true monster!
-Drew.
https://www.sau.com.au/forums/topic/427949-hey-from-brisbane/
Hey Drew,
Welcome to the forums! Feel free to venture into the QLD Section and introduce yourself. We have regular events, pretty much on a weekly basis and would love to have you come out.
Look forward to seeing you around!
Cheers,
Tony
of course youd love him to "come out"... :P
Hahah- I'd love to come out to (not "come out at") one of your events! I'll check it out for sure!
I'll chuck some photos up when i've got wheels and stuff sorted, don't really wanna claim it as "mine" with some terrible bob-jane wheels at its feet :closedeyes:
Thanks guys!
Thanks guys!
post pics now, then we can see how much of an improvement the new additions are.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
