Have you got your vent hoses routed correctly?
When I first got my car it blew smoke out the exhaust when cold due to the catch can being routed incorrectly.
Worth a look anyway.
Otherwise, dodgy injector, turbo seal, etc.
If looking for specific engine wear issues that could cause it, then worn rings allow a lot of blowby when on boost, pushing oil up into the head, then worn valve stem seals allow the engine to suck the extra oil back into the cylinders, leading to smoky exhaust.
But given that few of these cars haven't been bastardised, as well as raped, by previous owners, do check the suggestions of the above posters.
  • Like 1
If looking for specific engine wear issues that could cause it, then worn rings allow a lot of blowby when on boost, pushing oil up into the head, then worn valve stem seals allow the engine to suck the extra oil back into the cylinders, leading to smoky exhaust.But given that few of these cars haven't been bastardised, as well as raped, by previous owners, do check the suggestions of the above posters.
missed it but that is a very good point ill get the compression tested that shoud tell me if the rings are not sealing properly right? I ended up frying the clutch this morning so that's gone to the top of the list at the moment
