Hi all,
I am in the process of getting some bonnet dampers in to suit R33/R34 and possibly S13's. If anyone is keen on a set I will place a larger order so I can get the price down.
At the moment it is looking to be around the $70 for a black set and $100 for a carbon set.
Will know exactly how much when I place the order, the $$ is tanking which is a bit crappy.
This is just a EOI at the moment, still a couple of weeks away from confirming anything.
Who is keen?
https://www.sau.com.au/forums/topic/428030-eoi-skyline-bonnet-dampers/
I'd be keen for a set. Been meaning to getting some just never got around to it. I assume they're universal? So no specific brackets or anything..?
Im interested. I have a 180sx (240sx kit because its american) on mine and the struts were to strong and slightly to long so I couldnt use them. The ones I do have are too weak.
Got any pics of the kit you have in mind?
Ill ask about 32's as well.
These dampers are only for GTST/GTT, the bonnets are around the 17kg mark and the dampers are made for this weight.
If I get enough interest Ill see about dampers for GTR's. Can anyone tell me the weight of a GTR bonnet?
I want to order some sample sets for different models so ideally I would like some willing people to test fit these.
ER34
R32 GTST
S13 Silvia
S14 Silvia
I am assured these work with these model/weight bonnets.
If you have the above model and would be keen on a set shoot me a PM. A small deposit will be required.
Here is a pic of what to expect:
First in with PM and deposit gets it :)
I'd like to have the cars at my place so I can check install and operation.
Tried to PM before but got an error that you couldn't receive messages.
Matts probably closer if it is for a test fit! So try it out and let me know how you go :)
Either way if you can make them work i am keen! Would be pretty handy considering the amount of time i spend under the bonnet lolz
Agreed. More room with a higher bonnet plus no obstruction when working. WIN WIN!
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
