Hi all,
I am in the process of getting some bonnet dampers in to suit R33/R34 and possibly S13's. If anyone is keen on a set I will place a larger order so I can get the price down.
At the moment it is looking to be around the $70 for a black set and $100 for a carbon set.
Will know exactly how much when I place the order, the $$ is tanking which is a bit crappy.
This is just a EOI at the moment, still a couple of weeks away from confirming anything.
Who is keen?
https://www.sau.com.au/forums/topic/428030-eoi-skyline-bonnet-dampers/
I'd be keen for a set. Been meaning to getting some just never got around to it. I assume they're universal? So no specific brackets or anything..?
Im interested. I have a 180sx (240sx kit because its american) on mine and the struts were to strong and slightly to long so I couldnt use them. The ones I do have are too weak.
Got any pics of the kit you have in mind?
Ill ask about 32's as well.
These dampers are only for GTST/GTT, the bonnets are around the 17kg mark and the dampers are made for this weight.
If I get enough interest Ill see about dampers for GTR's. Can anyone tell me the weight of a GTR bonnet?
I want to order some sample sets for different models so ideally I would like some willing people to test fit these.
ER34
R32 GTST
S13 Silvia
S14 Silvia
I am assured these work with these model/weight bonnets.
If you have the above model and would be keen on a set shoot me a PM. A small deposit will be required.
Here is a pic of what to expect:
First in with PM and deposit gets it :)
I'd like to have the cars at my place so I can check install and operation.
Tried to PM before but got an error that you couldn't receive messages.
Matts probably closer if it is for a test fit! So try it out and let me know how you go :)
Either way if you can make them work i am keen! Would be pretty handy considering the amount of time i spend under the bonnet lolz
Agreed. More room with a higher bonnet plus no obstruction when working. WIN WIN!
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
