ID have released a all new injector the "ID1300", tech info http://www.injectordynamics.com/ID1300.html
Introducing the ID1300
When we let the cat out of the bag at the PRI show in November, we had no idea we would get the kind of response that we did.
Instead of answering questions about when it will be ready, we are hearing from dealers, and individuals who tell us that their build is on hold until they get their hands on them.
Well guys...we are as excited as you are, but we are also unwilling to release an injector until it is good enough that we can call it the best, without reservation, regardless of the application.
What we are willing to do is use this opportunity to tell you a little bit more about it, and how it came to be.
The ID1300 is the result of a technical partnership between Injector Dynamics, and Bosch Motorsport This partnership allows us to start with a clean sheet of paper, to develop an injector with characteristics that will make it perform well in a wide variety of performance applications.
The ID1300 Offers
  • Compatibility with all known fuels.
  • Stable operation over a broad pressure range.
  • Low minimum fuel volume, capable of stoichiometric idle in small displacement engines.
  • Smooth controlled response at low pulse widths, allowing accurate linearization using all OEM methods (Ford, GM, Chrysler, Porsche, Subaru, etc.)
Coming soon to a dealer near you...
cut and pasted from there website
wondering if anyone has any ideas or thoughts about them, I put a set on order yesterday and they will be available in 2-3 weeks
https://www.sau.com.au/forums/topic/428032-id1300/
Interesting, especially given they are short form factor injectors. At low pulse widths they have a noticeable spike in fuel delivery (see linearity deviation curves) but as for how much difference this actually makes.... I'm not sure. It depends on what kind of pulsewidths you're running at idle but it is a different characteristic to their other injectors.
Another excuse to hold off on injector purchases until I hear more about these :unsure:
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6914675
  • 3 weeks later...
Was hunting down injectors and i heard that they tested these injectors with a much thinner viscocity compared to that of the fuel we use. If i can find an article i will post.
even if that is the case who cares. injector dynamics have an excellent reputation.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6949956
BS....
They're one of the only injector companies that don't use 'test fluid'.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6950049
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
