ID have released a all new injector the "ID1300", tech info http://www.injectordynamics.com/ID1300.html
Introducing the ID1300
When we let the cat out of the bag at the PRI show in November, we had no idea we would get the kind of response that we did.
Instead of answering questions about when it will be ready, we are hearing from dealers, and individuals who tell us that their build is on hold until they get their hands on them.
Well guys...we are as excited as you are, but we are also unwilling to release an injector until it is good enough that we can call it the best, without reservation, regardless of the application.
What we are willing to do is use this opportunity to tell you a little bit more about it, and how it came to be.
The ID1300 is the result of a technical partnership between Injector Dynamics, and Bosch Motorsport This partnership allows us to start with a clean sheet of paper, to develop an injector with characteristics that will make it perform well in a wide variety of performance applications.
The ID1300 Offers
  • Compatibility with all known fuels.
  • Stable operation over a broad pressure range.
  • Low minimum fuel volume, capable of stoichiometric idle in small displacement engines.
  • Smooth controlled response at low pulse widths, allowing accurate linearization using all OEM methods (Ford, GM, Chrysler, Porsche, Subaru, etc.)
Coming soon to a dealer near you...
cut and pasted from there website
wondering if anyone has any ideas or thoughts about them, I put a set on order yesterday and they will be available in 2-3 weeks
https://www.sau.com.au/forums/topic/428032-id1300/
Interesting, especially given they are short form factor injectors. At low pulse widths they have a noticeable spike in fuel delivery (see linearity deviation curves) but as for how much difference this actually makes.... I'm not sure. It depends on what kind of pulsewidths you're running at idle but it is a different characteristic to their other injectors.
Another excuse to hold off on injector purchases until I hear more about these :unsure:
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6914675
  • 3 weeks later...
Was hunting down injectors and i heard that they tested these injectors with a much thinner viscocity compared to that of the fuel we use. If i can find an article i will post.
even if that is the case who cares. injector dynamics have an excellent reputation.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6949956
BS....
They're one of the only injector companies that don't use 'test fluid'.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6950049
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
