After searching these forums (and others) I've become confused about the recommended battery size.
The Century NS60LS has been recommended (430CCA, 47Ah.) Length 234mm, Width 129mm, Height 201mm.
However, in the G35 / 350z forums, they recommend 'Group 35' batteries, such as:
Optima d35 (650CCA, 48Ah.) Length 238mm, Width 173mm, Height 199mm.
The 5cm difference in length is significant, as the battery won't fit into the holder correctly.
What is the recommended dimensions for the battery in an '03 coupe?
The G35 uses a much larger battery, not sure why the Skyline got a smaller battery, perhaps something to do with space when mounted on the left side of the car vs the right side.
Not sure what the maxium size you can fit in ours, but the NS60LS is the battery type I have seen recommended.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
    • I've heard people claim with Just Cars (now defunct) and have been paid out, but painful process, and with Shannons, but noone I know or heard of has claimed with Enthusiast, hence I'm a bit nervous with their policy. Sure I'm "covered" but am I? is the real question
    • I have the Century CC1206 12V 1/3/6Amp 9 Stage Battery Charger. It is different from the one you linked but I don't know in what way. Their manual says that it both can be left on 24/7 and that it shouldn't be left on 24/7. Go figure ¯\_(ツ)_/¯ I haven't been game to leave it on there for more than 2 days.
