Something Easy To Make On A 3 Axis Cnc Mill Have Some Free Time But Carnt Think Of Anything
Depending how simple you want to go you could do something as easy as a slip on spacer that locates to the hub.
Slightly more technical than that would be a bolt on spacer.
Realistically they should have tolerances but shouldn't be too much of an issue if it's just teaching you to use the machine. Still requires some measuring and tool paths.
I've been making Man Sized LEGO out of MDF on my CNC at work. LOL
Oh and a double side Prop/Fan Blade... Would love to play with metal. \m/
How about something simple but expensive from nissan.
Like the heater core pipes. those plastic ones that bolt onto the core and cost $120 each.
One has a simple valve for heater control. You could get a ball valve or something for that bit.
Make something useful, and make some $$$
  • 4 months later...
haha that's awesome!! got any pics?
  • 3 months later...
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
