Hey there everyone. Although i own a Silvia (s13) I'm doing the age old RB25DET conversion on it for a Drift Pig. :P I came here purely for the knowledge that you all you guys possess about the sweet 25's. I plan on going above the 400KW mark, been reading through build threads all morning. I'll be running a 26 crank with rods, ect. any info / tips you guys have are much appreciated! As well as shops you guys use. I've got a few mates with Skylines and i guess you could say that Power FC limiter made me fall in love with the 25.
Cheers Andrew.
https://www.sau.com.au/forums/topic/428098-hey/
An S13 is pretty light, even an RB25 stock engine with bolt ons will give you a responsive 300-350kw which should be more than enough! No need to build an engine!
Spend the money wisely on bolt ons and maintanance and enjoy, but dont limiter bash an RB too long or bad things happen!
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916284
Keep cruising around and reading! When mine was making 350kw it was hard to get the power down to the ground through decent 265 tyres.... Now with 390ish it is going to be harder again! Keeping in mind my car is a few hundred kilos heavier than the S13! Get a stock engine with all the good bolt ons and screamer pipe (You said its a drift car) and you will impress your mates lolz
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916316
Yeah that is true, but traction isn't really a thing you need at the rears on a drift car. But still a valid point none the less.
To a degree it is i believe, you still want to be accelerating forward and have some form of grip.... Otherwise the run would just be a powerskid, different sport :P
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916468
Maybe in a year or two at winton? XD
Lol get back to me when you are ready!
For now, do your research on here! So much good info!
Have a look through my build thread in my sig to show what bolt ons can do to a stock motor!
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916506
welcome.
if you want something different, can I suggest a jag 6cyl?
but srsly, as mat has said above, bolt ons and maintenance for what youre going to do with the car.
have a read of his build thread, youll see whats achievable with bolt ons.
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6917920
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
