Ay yo! Does anyone know how to easily remove the black soot from the rear bumper without using so much elbow grease, or is there a reason why this happens and how can/ if you can stop it.
My engine has been modified with the usual things, or is there something possibly wrong with the engine
I've seen it on other cars as well, that have been modified so wonder if it annoys them just as much.
Questions, thoughts, answers? :geek:
https://www.sau.com.au/forums/topic/428125-black-soot-buildup/
So is that why i see a lot of white smoke come out of my exhaust when i leave work, i try not to give it gas, but when i even give it the slightest,it spewin out a 40 year olds smokers cough.
I need a mechanical answer to make the engine run right
White smoke... no good... :unsure: I'd get that checked up.
The black stuff should be concentrated around your bumper and boot, might just be because shes running a bit rich. After a wash it takes a few days for that stuff to build up again behind my car, if you leave it on for a long while you'll need to use a clay bar to get it off, otherwise a wash or a wipe with a detailer spray should suffice.
I don't know but i would say it looks more like exhaust fumes, heavy exhaust fumes under load, not white smoke, that was a bit of over exaggeration.
But it looks bad in the rear view and i wouldn't like to be behind me when that happens.
If i got a retune and made it run lean/leaner, would it
A. Reduce the black soot
B. Reduce hp
C. Make the engine struggle for fuel
D. Get more KM's out of a tank of fuel
This is not a game show.
Also just tried a wax and grease remover from repco and WD40 on bumper and came up tits..................that sounds weird.
turtle wax bug and tar remover - best thing i have ever used.
I'm probably one of the most anal people on here when it comes to keeping the car clean and this stuff for this purpose is farken amazing. And completely safe as designed to clean and be gentle on paint.
  • Like 1
Agreed +1
I tackled this yesturday, i havn't taken before and after pictures because i really didn't know it'd go so well, but my results were brilliant =). I'll just number my steps below:
1. Washed car day before.
2. Quick wipe with microfibre cloth and Meguiars quick detailer to remove loose dirt/soot.
3. Clayed the boot lid and rear bar with Mother California clay bar kit (love it).
Breaking away from the steps, there's something i need to point out. Looking right at the paint, on the boot lid there are many small black spots kinda stuck to the paint, only a clay bar can take it off. My 33 is white so i can see them easily. On the bumper the story is a little different, especially just above the exhaust exit, there seems to be a dark yellow stain covering 45% or so of the bumper. The clay bar takes this off, but very slowly, step 4 REALLY helped here.
4. I applied a bit of Meguiars Paint Cleaner with a foam applicator pad, then polished it with a $60 polisher wearing a woolen pad. I also went over it by hand with a microfibre towel, and the result was exactly what i was hoping for, complete whitenesss! I guess this product can be substituted with the turtle wax bug and tar remover, but i have not tried it for this application.
5. Meguairs Ultimate compound, buff, wipe off.
6. Meguairs nex gen tech wax 2.0.... apply, wait, buff off... mmmmmm sily smooth whitenessssss.
I really love the results, and it did not take too long either, maybe 25mints, and soooo worth it. Now i just need to see how long it lasts and also how easy it will be to remove the next buildup with the wax protecting the surface.
Just to let you guys know, when cleaning headlights its never worth using single products i.e. bug and tar remover, brasso bla bla bla... it might clean it, but after a few weeks yellow fever will hit you back hard, and that is because you have not sealed it back. Get yourself the turtle wax headlight restorer kit and spend 30 mints on it, you'll be much happier in the long run! :cheers:
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
