hey all so ive built an rb30de ( will turbo it later but for rwc no turbo cos its in a aus r31) the build consists of.
-r33 rb25det vct head with non vct cams.
-rb20det red top cams.
-standard rb30 bottom end.
-rb25det oil pump.
-series 2 ecu/coil packs and loom.
my first problem was a rattle in the top end at around 3500-4000rpm, and a missfire that would only occur when the motor was cold and the motor was given a little rev it would drop a cylinder and pick it back up when the motor had a bit of heat in it, so i pulled out the lifters and pulled them apart and cleaned and primed them and got rid of the vct cams because thats where the rattle was coming from, fixed that rattle but its now an absolute nighmare to start from cold, what seems to be happening is that the exhaust side lifters are pumping up on cold start and holding the valves open a touch, it starts up perfect but a few seconds after it starts when it gains full oil pressure its dies and when cranking to start it up again it sounds like only half the cylinders have compression. the only way to get it going is and soon as the motor fired bring the revs up to about 3.5k (the combustion pressures must be enough to keep the valves from opening) till it has warmed the oil a bit and then it runs absolutely perfect, no issues whatsoever.
Im starting to run out of ideas as to what could be wrong with the damn thing so if anyone has any ideas id really appreciate it!
did you use reground cams/new lifters? if you mix n match secondhand parts they will rattle(noisy) for sure
No they are the original lifters for that head and rb20 red top cams, I have no rattles, they exact opposite the lifters do more than taking up the lash between lifters and cams they over do it an start opening valves when they should be shut
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
