Yet another great SAU-NSW tech night - massive thanks to Terry for doing most of the organising, and to Todd, Adam and the crew @ JLM for hosting it, feeding us, and answering a bunch of questions (and servicing mine and Terry's cars, and doing a quick check-over on Luke's).
Got photos? Got opinions on the information given on the night? Got ideas for our next one? Post them in here!
I had a great time thanks - with like minded friends - all of you :)
Thanks to Todd and Andrew for distinguished presentations.
Plus Mtzu, Adam and Maurice Snr/Jnr for working on Nick's and my car. Hope the CV boot behaves itself this time Nick (1st time JLM have seen your car - a credit to you too).
'twas the first time I have seen a car serviced with "flair"! Some of Mtzus little touches made me smile.
Was good getting a better idea of the interactive parties involved in the importing process, and some of the more commonly made mistakes.
Was a good night, glad to finally put some faces to names. All top blokes.
Thanks to all for organising. Todd touched on all the important "issues" most of us face with our cars and gave clear advice and solutions.
In saying that he was very open about the fact that the rules are not in our favour and explained that it is down to the individual on how much risk they want to take driving their defect magnets :P
Clinton and I had a great night and the guys from JLM should be commended for putting on such a good evening and providing very good information.
I will have to call in and see them and pick up some of their Tyre Placards as we run 18 x 9's on all of our cars and it would just make it that much easier if you are pulled over as it is then something obvious that you cannot get defected for.
My only problem for the night was loosing a set of reading glasses which probably dropped out of my coat onto the floor somewhere.
wow.
great night.
the biggest thanks to terry for organising.
and even more so to todd and the guys for hosting is, and staying until well past midnight.
a very broad range of topics touched upon, which was very nice to see.
think if we ever do this again, ill organise a pizza or 2 for todd and I ;)
one last thing, I really appreciated todd letting me put my car on the hoist to check out the gearbox leak.
turned out to be the breather.
and if you read this todd, the centre bearing is done, gearbox mount replaced, a little more spacing added to gbox cross member and centre bearing, and the vibration is almost completely gone.
Please - do tell! :)
PS How's your busted knee Mat?
Just tiny things like the way he removed the sump plug. Something I as a home mechanic wouldn't have though of, like drawing the plug away really quickly as to not get covered in oil. Seeing him give it a little tap once he had re tensioned it after draining. Like a mental check.
Again, the way he bled the brakes specifying hard or soft stokes.
I like the fact you used Nissan filters. :)
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
