Hi everybody
Yet another newbie here, and yes I have tried using the search bar with no result,
Ive picked myself up a series 1 r33 gts (slowly finding out it may be a lemon) anyway recently my front right wheel is starting to hum while driving, just wondering if it would be my wheel bearing?
Could be... Jack it up, grab the wheel and give it a wobble.
Could be tyre / road noise especially if the tyre pressure is wrong, tyre is different to others or even tyre is on backwards.
More likely to be a bearing then.
Don't buy cheap bearings either, you'll be replacing them again shortly.
Did a bearing recently on a different type of car, $600 done and dusted (In the middle of moving and don't have time or space to change it myself)
Not necessarily.
1. is the front right tyre the same as the rest (Type,size,brand)
2. What's the tyre wear like
3. What type of tyre - meaning are they directional and/or asymmetrical or standard - symmetrical (same pattern across the tread)
- Some High performance cars are fitted with directional and asymmetric tyres. These must be fitted the right way round on the wheel and on the correct side of the vehicle
(Eg: Arrow facing forward and "outside" on the outside)
Yes it can make a humming noise. It's happened to me :wacko:
I thought that as well but if that was the case wouldn't the sound be coming from all 4? All the tyres still have good tread on them,
Edited by Sinista32
Cheers for the replies guys,
All the tyres are the same brand and size from what I can tell they are cheap "performance"$155 a tyre, I will get them to check it out when it's due for a service, doesn't effect the driving of the car just means I have to be like every other p plater for now and have the stereo up to loud for even my liking
If it's not the tyres, take it to your mechanic straight away. If it's the bearing, things will start to get more loose, and the wheel will end up with play in it. Not only is it terrible for handling and safety, it will also chew your tyre out majorly.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
