Hi everybody
Yet another newbie here, and yes I have tried using the search bar with no result,
Ive picked myself up a series 1 r33 gts (slowly finding out it may be a lemon) anyway recently my front right wheel is starting to hum while driving, just wondering if it would be my wheel bearing?
Could be... Jack it up, grab the wheel and give it a wobble.
Could be tyre / road noise especially if the tyre pressure is wrong, tyre is different to others or even tyre is on backwards.
More likely to be a bearing then.
Don't buy cheap bearings either, you'll be replacing them again shortly.
Did a bearing recently on a different type of car, $600 done and dusted (In the middle of moving and don't have time or space to change it myself)
Not necessarily.
1. is the front right tyre the same as the rest (Type,size,brand)
2. What's the tyre wear like
3. What type of tyre - meaning are they directional and/or asymmetrical or standard - symmetrical (same pattern across the tread)
- Some High performance cars are fitted with directional and asymmetric tyres. These must be fitted the right way round on the wheel and on the correct side of the vehicle
(Eg: Arrow facing forward and "outside" on the outside)
Yes it can make a humming noise. It's happened to me :wacko:
I thought that as well but if that was the case wouldn't the sound be coming from all 4? All the tyres still have good tread on them,
Edited by Sinista32
Cheers for the replies guys,
All the tyres are the same brand and size from what I can tell they are cheap "performance"$155 a tyre, I will get them to check it out when it's due for a service, doesn't effect the driving of the car just means I have to be like every other p plater for now and have the stereo up to loud for even my liking
If it's not the tyres, take it to your mechanic straight away. If it's the bearing, things will start to get more loose, and the wheel will end up with play in it. Not only is it terrible for handling and safety, it will also chew your tyre out majorly.
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
