  • Replies 63
Can anyone explain the duration to me??
Duration of a camshaft is how long it keeps the
Inlet/exhaust valve open for. So if you look af a 360* wheel and you have 260* cams, the camshaft has to go around 260* before the valve closes again. Lift is how far the valve opens as in height. So if standard camshafts lift is 8.5
And your aftermarket camshafts lift is 10.25
Then obviously the cam lobe is going to push the valve down open further by 1.75 which there for increase's air intake to in most cases create more horsepower. :)
Just a basic run down if you can't get your head around it I can be more thorough.
Cheers Josh.
which 260s did you have ? would be awsome if you have before and after dyno charts to see the difference between the two cams ?
There is no real difference loaded up on the dyno. I've seen a back to back, graph actually looks pretty close.
Same as -9s and -5s on the dyno, they don't look worlds apart in response or anything.
But the difference lies in the transient response or on/off throttle on the dyno and that's where things were noticed. Also dependant on the headwork that's actually been done, that compliments the cam setup, so it's no one singular thing
If the change was same setup to same setup and the only change was cams then it would been interesting to see the difference
I've seen on my 34 the difference from going to type Rs from type Bs and it was a fair bit, same peak power but every thing happened 800 rpm sooner give or take
so for my 6266 turbo (medium size single turbo) which already has a lot of grunt up top, would benefit from type R cams or there abouts, small duration 9.1 lift, to help spool and bottom end response
wonder why so many people go type b then
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
