So at Matsuri, the car went from looking like this...1922014_639959332706435_1934333717_n.jpg
...to this... :/20140223_090210_zpsqarlvnvc.jpg
The new front end setup was just too stiff, consequently, the car had a lot of understeer. In hindsight, I should have tried to tune it out instead of driving around it. Combine this with copious amounts of rear grip, and running new tyres at low pressure, meant the car was very quick and on this one occasion the speed caught me off guard.
Sorry to see you had a "mishap" on the weekend man, any damage to the wheel or suspension?
Considering, that could have been a lot worse, and to be honest for a drift matsuri, if that's the worst that happened the car held up well ;P
Thanks Danial, Tim, you are right, it could have been worse. Because the Ikeya Formula control arms are so strong, they transferred all the force in to the engine subframe and k-frame, elongating the mounting holes for the pick-up points and bending it out of shape. The arms actually look okay, but I'm yet to pull it all down. Plus I think the rad support is a bit out of shape.Only the lips of the rims we damaged, so they should be fixable with some work.
  • 4 months later...
It's time to update this. Unfortunately, it's not going to be a 'big reveal', that some, myself included, may have be hoping for. Truth be told, the car has been sitting in a corner of the workshop being neglected since the crash. For some reason I took the whole ordeal to heart and I'd be lying if I didn't say that the black dog has reared its ugly head again. Nonetheless work has begun, and progress is progress.
The first thing to do, was to change out the bent crossmember. In lieu of this, I ordered a set of Nismo engine mounts.
To support the motor while I dropped the cross member, I fitted this home made engine stand.
Out with the old.
As you can see, the LH engine mount was broken. This confirmed my earlier suspicions.
It took a fair old hit, and you can see here, just how badly it was bent.
It even bent the bolt.
In with the new.
I also took the liberty of replacing the castor arm brackets, but neglected to get a picture of this. The Nismo gearbox mount fitted up.
The long Nismo box, pictured earlier, contained this boot brace which I fitted to help stiffen up the rear end.
More to follow.
Glad to see some progress Tim! Can't believe how bad that subframe was, was a bigger hit than I thought!
Hope everything is going well for you mate, can't wait to see you back out on the track :)
  • Like 1
Continuing with the N1 theme.
A pair of brand new N1 headlights. The crash broke all the mounts on my projector headlights, and while I do prefer the look of the projectors, I just couldn't go past this cheaper and cooler option.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
