Today I loaded up the old work van and anxiously delivered the wheels and tyres to be fitted. I Dropped off some beers at the same time, just as some extra incentive for the workers to look after the rims. And i'm happy to report that they did a good job and that the wheels look great. The 215/45 federal 595's look quite squarish on the 9.5" rims, but hopefully they provide some extra clearance.
I also finished sandblasting the last of the Brembo calipers. Fortunately, we are lucky enough to have a machine shop just across the road, and they gave me full access to their workshop, in exchange for beers, including the use of their hot-wash and sandblaster. Their sandblaster uses a super fine glass media that gives an excellent finish. It's almost going to a shame to paint them. I think they look great in their raw alloy state. Thoughts?
Edited by White GTS-T
  • 3 weeks later...
^Agreed. How is your 25 conversion progressing along since the first start up? I had a go at painting the calipers with some VHT pressure pack and it turned out okay, but I have since stripped them again and sent them to the powder coaters. Here's my rattle can attempt.
So the boss told me I had too many holidays saved up, so I've taken a few days off to get the car sorted, somewhat. Using the Takata LDS I can now make it on and off the four post hoist trouble free. So I put them and the Ikeya Formula Maple A-one gauges to use...
...adjusting the camber...
...and toe...
...after installing the Ikeya Formula arms, front and rear.
Now I just need to get some swivel plates and a bubble gauge to measure castor. The new arms were accompanied by new sway bar links.
Lastly, I test fitted the new wheels, and much to my surprise they don't stick out as far as I thought they would.
  • 3 weeks later...
So I finally picked up my calipers from the powder coaters and upon first glance I was initially disappointed that that the colour was a lot lighter than what I had selected on the sample chart, I thought it was going to be deeper. But upon fitting them, the colour has really grown on me. I think they compliment the wheels nicely without being too overstated, which I think red would have been. It's quite difficult to do the calipers justice with a camera phone, the metallic silver really has to be seen in person, the finish is outstanding, much better than my efforts.
I promptly rebuilt all the calipers with the new seals, boots etc and got on to the fitting. I started on the rear and prepped the handbrake shoes and the hubs for the new discs.
Prepped the new rear pads.
Rear sorted, with new Rays hub rings and a coat of paint for the space that can be seen due to not having center caps.
Front pads prepped.
Again, same treatment for the front.
I cleaned up all of the retaining pin kit and fitted the new braided lines.
Routing them neatly.
Looking good all mounted up.
After bleeding the system with some fresh Motul fluid, everything's ready for the bedding in process.
^Cheers. I am definitely interested in trying my hand at some circuit work. What 'tweaks' would you recommend? Since the installation of the Ikeya Formula gear I decided to try a very aggressive alignment. It's currently running;
Front:
Camber: -4.5 degrees
Castor: 8 degrees
Toe: 10mm total toe out.
Rear:
Camber: -1.5 degrees
Toe: 0
The car feels very solid and planted now. Kind of how i'd imagine a circuit car to be set up. The front feels less nimble now, due to the wider front wheels perhaps, and the steering is a lot heavier but much more direct.
^Thanks. Only some spirited street driving as of yet, but so far so good. The car is very twitchy, but the turn in is super responsive. I loved the way the car handled prior to all the recent work, so I can only hope that car setup hasn't gone 'backwards', so to speak.
So I tied to take a better photo of the brakes in some more natural light, both before and after the bedding in process.
Before:
After:
Rear:
Coming from run of the mill Bendix Ultimates, this new setup is incredible. The pedal feel is so connected, I was easily able to find the limit of the Federals...and beyond. Almost flat spotting the brand new tyres at one stage. :blush: I'm very impressed to say the least and quite eager to put everything to the test, at a circuit day or similar.
I also fitted up a braided clutch line with a hose that was left over from the brake hose kit. It's a tad long, but it does the job.
Some fresh Motul fluid for the clutch and its good to go. While I was at it, I fitted the reservoir covers. I'm not so sure how I feel about these, as it's the first real 'dress up' mod that the car has received, but I guess they look better than the dirty old socks I had on there...
That is a very agrressive alignment! Unless you're using slicks?
For road tyres & semi slicks:
Front -
Camber -3.25 to -3.5 degrees
Toe 1.75mm out each side (help the front turn in)
Rear -
Camber -1.75 degrees
Toe 1mm in each side (reduce oversteer)
Come to the SAU rounds!
John Richo is the fastest gtst & a wealth of knowledge. Not sure when the next round is... Are you coming to WTAC next month?
I wasn't planning on going to WTAC, but i'm sure it would be incredible, i'll look in to some flights.
If I was going to do a circuit day I would dial the alignment back a bit. Half the reason it's so aggressive at the moment is just to fit the wheels. Once I get the GT-R front guards I've got, painted and fitted, I will be able to stand the wheels up some more.
I'll definitely keep an eye out for the SAU rounds, that sounds right up my alley.
On a lighter note, I decided to give the exterior some love. I've been toying with the idea of respraying the car, but before committing to that I decided to give the car a polish for the second time since owning it. I didn't really know what I was doing, to be honest, but it turned out okay.
I took this mediocre snap before the sun went down.
Sorry I missed this post vvv Its coming along alright, wish I had more time to work on it though. Yours is looking good, the callipers turned out nice! Pretty impressive setup, as said would be a solid base for some fast laps.
^Cheers. Glad to see your shake down was 'relatively' trouble free. Yeah, now that I look at it, the car is starting to get pretty serious. I guess I'm just fortunate enough to be in a position where I've got a bit of money put away and I can finally get it to the stage that I always imagined it to be, when I was struggling through my apprenticeship.
Damn that came up shinny!
And come to WTAC! $200 in flights check out the mental cars.
SAU rounds are run with the WRX club normally. Are you an SAU paid member? Got a CAMS license? Ready to rumble :)
Post pics of the beast with the GTR guards on when it's all done.
Yeah I was surprised how well the paint came up. When I first started rubbing the bonnet with the clay bar it sounded like sandpaper, it was so rough. But after a little rubbing it was silent and is now so smooth to touch. I can stop touching it. :blush:
Mmm World Time Attack *drools. I've been following the builds of as many cars as I can and some of them are just mental. It makes me moist. Urge to go, rising.
I sent in an application to become an SAU member just the other day and today printed off the CAMS paper work to renew my expired L2NS licence.
I'm not sure which direction I'm going to go aesthetically, in regards to the exterior, but I have the following parts here to go that just need to be painted.
Moonface racing rear wiper delete.
Boot with no spoiler holes.
N1 boot lip (new)
Dmax roof spoiler (new)
Genuine Ganador mirrors. (new)
GT-R front guards.
N1 bonnet lip
N1 lower lip (New)
N1 front bumper vents (New)
GT-R indicators (New)
GT-R N1 front bumper (is on back order)
N1 boot lip (new)
GT-R front guards.
N1 bonnet lip
N1 lower lip (New)
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
