HELP!!! defected again and first EPA.........
The person that told you about the turbo timer needing to be removed for EPA test is an idiot.
EPA are only interested in your cars emissions; they will test your exhaust emissions and check under your engine bay for BOV's, intercooler or air pod - one or the other.
Turbo timer does not affect your cars emissions so you dont need to remove it. However a boost controller would need to be removed.
Somebody mentioned something about not having a Turbo Timer? I have an EPA test on my 32 GTST on November 10th. The car is pretty much stock apart from exhaust and frontmount. I'm not sure exactly how loud the exhaust is, but it isn't one of those 1s that rumbles all day long, pretty quiet on idle too. So basically, turbo timer must be removed for EPA testing????? :)
  • Replies 52
Lads good tread i am from WA wat is wrong with boost controlers if noise and edmisions is wat the are after
i have an eboost2 looks like a gauge but i sopose the solanoid would get you done
wat if your hoses were black and not red or yellow you no not as obvios would that help
They are not after noise emissions on a Full Test.
The are after ALL Emissions.
WA is nothing like Vic. I've seen what you guys get away with over there. Its nothing like here.
A Boost controller gives you the ability to alter the cars boost level, which alters the emissions = illegal in Victoria.
The EPA are NOT stupid. They know what to look for. Been there, done it. You "can" hide some things. But for the most part you cant
there is nothing wrong with it at all, i use it a ridiculous amount.
If im looking for things or posting links in the FI section to help people out
Its not against the rules at all, but people some courtesy and common sense.
There are a number of people here who answer these questions day in and day out. Threads like this are a dime a dozen
Give them some justice and not make them post these things up every 2 weeks.
taso, make sure you click the "search title" button instead of the search post button..
you get more useable results that way :D
No offence to the designer of the search tool, but really it finds jack Sh^t.
Plus is it against the rules to ask questions on the forum or something?
yeah i just passed my EPA today. yay..
all they check is BOV, boost contoler, thay you only have 1 intake mod, emmisions levels<that you have a cat> , nosie and that you have std ecu<via console port i think>. They are pritty nice guys after they were done my mate tried to convince him that the pfc could have less emmisions than the std ecu.. haha
Did you know your allowed to have a pfc if you pass a full labratory emmisions test. too bad the test is 4k per try. <_<
yes, its common knowledge about the test.
But what you find out if you inquire more is that if you fail it. You loose your $$$ on the spot.
There is no credit to return for a retest
And the test is around 3k if i recall correctly
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
