  • 3 years later...
  • 2 months later...
...and learn nothing? Thats how you get through life is it? Just never done it on anything post 1977.. something tells me procedures may have changed 30 years on. Not afraid to just give it a go but anything to make a job easier is worth asking about. I have no doubt you have the knowledge but no need to be so arrogant about it. Didnt know forums had a Dont know, don't ask, dont try policy
Edited by c34Florry
Changing plugs is heaps easy. If you need pictures you probably shouldn't be actually doing it.
a mate and this thread taught me to change the plugs in my rb,
everyones at a different point on a learning curve, you at one point didnt know how to either so no need to be a wank about it.
nevertheless i use bcpres-11 gapped at 1.1mm
works plenty fine for me and actually fixed a misfire issue so yeah, happy hunting!
  • 1 month later...
When i removed the plastic cover covering the loom and plugs, the seal around the plastic cover was really brital and broke off, i assume its for sealing off any water intake so next question is has anybody had this same issues and how did you replace it. Also th metal peice that hold the ports for the coils to plug into was broken? Where the fourth screw belongs i dunno if its supposed to be like that or no? Also just thought id add that th plugs i removed were NGK R- PFR5G-11 a bit different i thought.
Cheers if anyone can help
Heres a pic of the metal part that is broken
Edited by adamRB
  • Like 1
yeh, the sides of my valleycover were really brittle the first time i changed my plugs, and broke off. Not an issue though, and as previously said, just dont go about pouring water over your engine lol.
Never took the metal bit out that held the coils:\ didn't even know there was one lol. Arent the coils just screwed down with 2 screws?
Also, as said, use a torque wrench to prevent threading lol. I slightly threaded one of mine, not causing any issues but really careful now when i change em (i still dont use a torque wrench oops)
  • 3 years later...
torque settings for spark plugs in an alloy head should be no more than  23NM maximum, when brand new plug this will give proper crush gasket "squish" and ensure a good seal without damage to the plug or the head.
this torque setting doesn't seem like much but a preset plug tool can be purchased through specialist suppliers that sell to motorcycle mechanics and or speedway enthusiasts, i have a KINCHROME branded one for my 2 stroke race bikes and it has saved me a fortune in replacing cnc machined heads from being stripped when they are over $2500 per cylinder head and you have 4!
  • Like 1
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
