  • 3 years later...
  • 2 months later...
...and learn nothing? Thats how you get through life is it? Just never done it on anything post 1977.. something tells me procedures may have changed 30 years on. Not afraid to just give it a go but anything to make a job easier is worth asking about. I have no doubt you have the knowledge but no need to be so arrogant about it. Didnt know forums had a Dont know, don't ask, dont try policy
Edited by c34Florry
Changing plugs is heaps easy. If you need pictures you probably shouldn't be actually doing it.
a mate and this thread taught me to change the plugs in my rb,
everyones at a different point on a learning curve, you at one point didnt know how to either so no need to be a wank about it.
nevertheless i use bcpres-11 gapped at 1.1mm
works plenty fine for me and actually fixed a misfire issue so yeah, happy hunting!
  • 1 month later...
When i removed the plastic cover covering the loom and plugs, the seal around the plastic cover was really brital and broke off, i assume its for sealing off any water intake so next question is has anybody had this same issues and how did you replace it. Also th metal peice that hold the ports for the coils to plug into was broken? Where the fourth screw belongs i dunno if its supposed to be like that or no? Also just thought id add that th plugs i removed were NGK R- PFR5G-11 a bit different i thought.
Cheers if anyone can help
Heres a pic of the metal part that is broken
Edited by adamRB
  • Like 1
yeh, the sides of my valleycover were really brittle the first time i changed my plugs, and broke off. Not an issue though, and as previously said, just dont go about pouring water over your engine lol.
Never took the metal bit out that held the coils:\ didn't even know there was one lol. Arent the coils just screwed down with 2 screws?
Also, as said, use a torque wrench to prevent threading lol. I slightly threaded one of mine, not causing any issues but really careful now when i change em (i still dont use a torque wrench oops)
  • 3 years later...
torque settings for spark plugs in an alloy head should be no more than  23NM maximum, when brand new plug this will give proper crush gasket "squish" and ensure a good seal without damage to the plug or the head.
this torque setting doesn't seem like much but a preset plug tool can be purchased through specialist suppliers that sell to motorcycle mechanics and or speedway enthusiasts, i have a KINCHROME branded one for my 2 stroke race bikes and it has saved me a fortune in replacing cnc machined heads from being stripped when they are over $2500 per cylinder head and you have 4!
  • Like 1
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
