Are you talking about the standard narrow band or do you have an aftermarket wideband setup to install?
Stock narrowband can be mounted about 10-30cm downstream from the turbo outlet. But if you are playing with aftermarket ECU's (depending on which one you have) it may not be needed so just think about if it is needed.
As for wideband. Mine is mounted just before the Cat from memory. Mines an AEM unit and suggests about 1 metre or more of pipe before the sensor, and that the sensor is mounted about 30 degrees above the horizontal line
https://www.sau.com.au/forums/topic/428205-02-sensor/#findComment-6918222
