Genuine WALBRO 400LPH Fuel Pump + 2x Strainers
- Most popular in-tank performance fuel pump on the market today
- 400LPH supporting 750+HP applications
- Standard 38mm fuel pump design
- Genuine WALBRO – manufactured in USA by TI Automotive (box may be generic TI)
Comes with 2x strainers and everything pictured
- Most popular upgrade across the Nissan range; RB's, SR's, CA's ect.
$200 $180 incl. Delivery >> SAU Special
E85 compatible version now in stock - 460LPH - $220 incl. Delivery
* This is an Australian delivered product with a national warranty.
  • 6 months later...
  • 5 months later...
How does it make It easier?
What does the base do?
Hey!
It acts as a cradle to keep the unit mounted in the assembly, alternatively the bracket that holds the original pump may need to be modified to suit.
Common with CA20's and SR20's
  • 10 months later...
We can now just supply the pump on it's own for custom assembly's and set-ups.
Kit's incl. fittings ready to go if preferred as well!
Is this pump e85 and 98 compatiable?
Hi,
These unit's are not E85 compatible the higher flowing 450LPH unit's are though.
Brendan
(VM)
  • 2 months later...
  • 3 weeks later...
Also after a price for the 450 and how to purchase? Link is only for the 400?
Hi mate,
Sure, you can purchase a 450LPH set-up here; http://www.sau.com.au/forums/topic/410989-all-new-walbro-460lph-e85-in-tank-fuel-pump-strainer-kit/
As with the 400 these are genuine Walbro unit's.
Cheers,
Brendan
(VM)
Sorry to say but $235 is a sau special? That's more expensive than most Australian online performance shops.
That's a for a genuine unit! Not this Chinese stuff buddy.
What's the difference between a 450 and a 460?
Hi,
Sorry missed that one...
At an optimal 13.5V these flow 460LPH, but most users will get around 450LPH.
Same same,
Brendan
(VM)
  • Like 1
  • 3 months later...
I just noticed this thread. Is the 400lph drop in and connectors fitted for an r32 GTS-T?
Hi,
This is a universal kit so some minor tweaking will be required.
Brendan
(PEC)
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
