under the bonnet mate, all the light fuses and relays are there.
do you have the positions marked on the under bonnet fuse box cover? If not, take a pic of the fuses and we can check what they match.
BTW if you have a multimeter you can quickly check each fuse using the continuity check
Found it.... If anyone ever has the same problem it's the 5th 10A fuse down on the left in the box behind the battery. A blown glove box light on the same circuit caused it to blow. I must have knocked it when I installed a boost gauge a few weeks ago.
Ɨ
Ɨ
