Hi all,
Am selling some remaining items off my R34 and some items from an R32 GTR front-cut that are surplus to requirement:
R32
1. GTR horn button - $50
2. front calipers - $100 (can give you the rotors, but they've got a bit of lip to them)
3. ABS unit - $100
4. wiper bottle - $50
5. gearbox + transfer shaft + shifter, great condition - $500 (pref local buyer)
6. front pipe - $50
R34 (panels/tail light housing are black in colour and very good condition)
7. front fenders - $200 (pref local buyer)
8. rear spoiler (black) - $120 (pref local buyer)
9. front bar (black) - $200 (pref local buyer)
10. bonnet (black) - $200 (pref local buyer)
11. front reo bar - $50
12. rear bar - $150 (pref local buyer)
13. rear tail lights - $200
14. Nissan 15 x 6.5 wheels + 205/60/R195 90%+ tyres - $250 (pref local buyer)
Please contact/request pics and I'll put them up as best I can. Items are located in Western Australia,
Cheers
https://www.sau.com.au/forums/topic/428237-fs-r32-gtr-r34-pieces/
Front bar, guards, bonnet and reo bar sold now, update:
R32 GTR
3. ABS unit - $100
6. front pipe - $50
Various
15. R34 GTR fuel flap (very dark purple colour) - $50
16. R33 GTR front left driveshaft (good condition) - $120
17. R32 GTR front left driveshaft (good condition) - $120
  • 3 weeks later...
Updated and w/ new prices:
R32
GTR horn button - $40
ABS unit - $80
wiper bottle - $40
gearbox + transfer shaft + shifter - $400
R34
rear spoiler (black) - $100
rear bar (black) - $100
rear tail lights - $150
door cards both sides - $100
Nissan 15 x 6.5 wheels, 5x114.3 including 205/60/R195 with 90%+ tyres - $250
  • 3 weeks later...
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
