No doubt SAU has a few threads about this but can't find them and google just finds me 25 box into auto 32 etc etc
Usual thing happened, blew the rb20det gearbox drifting and want the rb25 box for the usual reasons.
This is what I know......
1. 25 yoke welded on the 32 tail shaft
2. Closs member fix (not 100% sure what needs doing)
3. Navara speed sensor (again, not 100% sure what needs doing)
Any info would be good and pics of what needs doing would be even better. Car has a 2530 so not sure if that'd make a difference.
Please no stupid comments or remarks
Thanks in advance.........Fliggy
Yuh, but that wasn't his question.
I had to swap crossmember when I did RB20 manual into auto R32. Then when I did RB25DET manual into the same car, I had to change crossmember again. I don't know for sure, but I strongly suspect I ended up with my original auto crossmember back in the car!
Fliggy, if you want someone to build a Navara sender up for you, contact Fours N More at Pooraka. They have done heaps of them. I suspect that they probably need at least some of either your R32 one or the R33 one. Apparenly it's not particularly hard, but I didn't pay any attention when it was being done to mine as I was either busy on some other part of the car or away overseas (I can't remember now, too long ago).
Otherwise, your list is about all the tricks involved. Take measurements of the lengths from the back of the new gearbox to the centrebearing studs on the car, and take your R32 tailshaft and the front half of the R33 one to Spicers and they'll cut and shut it for you. They do so many of them that if you walk in with the pieces they will recognise them and you won't even have to tell that what you want done.
Make sure you have the correct slave cylinder too, as they are different between R32 and R33.
  • 3 months later...
  • 9 months later...
Sorry to bring up an old thread but don't want to start a new one as I feel this has been answered but I cant find it.
I have an r32 manual with rb20det and box.
I also have just obtained a r34 RB25DET Neo with manual box flywheel everything as it came from the R34.
I want to put the 25 in the R32.... obviously
Is there anything I need to be aware of with the gearbox?
I just want to get all the parts I need before hand to make it as easy as possible.
Thanks
I had Neo and Neo box in my car. No different that fitting a standard RB25 box Into a 32.
RB20 box is 800mm long
RB25 box is 780mm long
RB25 box also had a different yoke to RB20. It's the same as 300ZX/VL turbo box. You need to acquire a yoke and then get it fitted to your RB20 tailshaft. You don't need to extend or shorten the shaft, keep it the same length.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
