Just don't want to see you get stung .
I am considering a GTR as my next car too, but anything that hasn't had a rebuild I am automatically factoring that into my budget as a future cost. I see it as a question if 'when' not 'if'.
If you're not able to diagnose it - paying for someone who knows their stuff to give it a once over could be a wise investment.
Yer if I choose to accept the challenge of the car I will be factoring in the rebuild, hence why I haven't bought it yet, and will be taking it to a specialist to diagnose the noise, so far have came up trumps with a video, they all really need the car to sort it out correctly.
Maybe ask the owner if you can bring someone out to the car and remove the cam gear/timing cover?
Would be an easy way to check for rubbing, belt condition and deflection.
There would surely be a member in your area who would do it on a Sunday arvo for a slab.
That noise sounds like what my car does but worse, mine has 180k's , new belt and no cover so be interested to know what causes the noise,
any pics of the car?
Edited by AngryRB
Will upload pics tomorrow as busy today and not at home. Pics on phone are too large.
As per k's visually engine bay and noise is not reassuring but everything else looks mint... Under the dust.
Edited by dbking82
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
