I got genuine Nissan ones from justjap in the last 12 months for the front of my 2000 C34 S2 RS4, I tried after market ones that a few members have recommended only to find out that the taper is incorrect. The genuine ones only cost about $100.00 each, I can't put my finger on the part number at the moment but justjap will sort it out for you. Mine were flogged out too. Regards Craig
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6920096
I use genuine ones aswell and i can confirm that the tie rod ends listed at auto stores are the wrong taper
34 Gtr ones are the correct taper but are to short.
So genuine it is , use search function the part number is on hear somewhere
Cheers
J
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6920119
Should be one of these (haven't had to buy one myself yet):
3 different tie rods outers for Stageas, depending on model, year, 4wd/2wd, MT/AT etc
48520-0cu25(2wd)
48520-15u25(4wd)
48520-23u25(4wd)
2 different for R33, both are same part # as 2 of the 3 Stagea tie rods.
48520-15u25(2wd)
48520-23u25(4wd)
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6921869
I found my invoice from JustJap. The correct part number is 48520-23U26 this is the genuine part number I got from Nissan which supersedes previous part numbers. I have had them on my 2000 C34 S2 RS Four Auto since November 2012 last year with no problems, as I stated before the aftermarket ones do not fit, they are dangerous as they feel like they pull up into the taper but there is insufficient clearance underneath leaving very little angle to pivot correctly and they flog out very quickly, I had them on the car for only a week waiting for the genuine ones to arrive and when I fitted the genuine ones, the aftermarket ones were worse than the ones I was replacing in the first place, the only good thing was they practically fell out of the taper when I undid the top nut! I hope this makes it clear re the correct part number, for info, they cost me $190.00 for the pair in November 2012 when I picked them up and Dan from Just Jap was extremely helpful. Craig
Edited by Zedhead70
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6922482
Ha ha was just looking through my receipts and zedhead hit the nail on the head that's the correct 1 and only part number for s1and s2 rs4 , a lot of the other aftermarket part company's will tell you other ones will fit but they won't they have the same size taper as a 34gtr i think 14mm but are a lot shorter in the shank .where as the ones listed at part dealers have a 12mm (too small) taper like 33/34 gtt but are correct shaft length ,
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6922575
I got these a while ago for my Series 2, 4WD. The suspension place said they were Identical to the originals and only $60 a pair. Quality seems to be good too.
You can email the seller to confirm fitment. From memory the packaging said made in Taiwan.
http://www.ebay.com.au/itm/2-OUTER-TIE-ROD-END-Set-NISSAN-STAGEA-4WD-96-01-/190638900925
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-6922651
  • 3 years later...
I guys just to clarify, does  48520-23U26 suit both the passenger and drivers side?
The guy at Nissan Spares today wasn't sure and said he cant get them.
He also said 48520-23U25 supersedes the above part, can get them, presently $150.79 landed in Aus.
(i think he got his superseding back the front :).
I was planning to get 48520-23U26, in reference to advice above and also i found these at Kudos.
http://www.kudosmotorsports.com/catalog/outer-front-nissan-skyline-stagea-wgnc34-260rs-25tx-four-four-four-p-1090.html
Cheers,
Pete
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-7833100
Thanks Tom,
Is yours series 1 or series 2?
Using my vin to search on my S2 RS4V AWD (11/98) they came back as 48520-23U25, so in turn I have ordered 48520-23U26 which is the newer part.
Now crossing fingers I have the correct part :).
Ditto on genuine.
Cheers,
Pete
Edited by Stagea_Neo
https://www.sau.com.au/forums/topic/428270-tie-rod-ends/#findComment-7833730
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
