Hey Guys
Pretty sure my car still has a compliance cat in it and i'm thinking it could be colapsed/dying
So options are:
Xforce - $156 pp http://www.ebay.com.au/itm/XFORCE-HI-FLOW-CERAMIC-RACING-CAT-S13-SILVIA-R32-R33-SKYLINE-/141009781243?pt=AU_Car_Parts_Accessories&hash=item20d4d681fb&_uhb=1
Venom 4" - $250 pp http://www.ebay.com.au/itm/3-Nissan-VENOM-High-Flow-Cat-Skyline-R32-R33-R34-GTST-GTR-S13-C33-A31-/251251072123?pt=AU_Car_Parts_Accessories&hash=item3a7fbb1c7b&_uhb=1
Venom 5" - $300 pp http://www.ebay.com.au/itm/3-Nissan-VENOM-High-Flow-Cat-Skyline-R32-R33-R34-GTST-GTR-S13-C33-A31-/261191191269?pt=AU_Car_Parts_Accessories&hash=item3cd0354ae5&_uhb=1
Catco Highflow - $175 pp http://justjap.com/store/product.php?productid=18066&cat=&page=1
Catco Metal Racing - $379 pp http://justjap.com/store/product.php?productid=16441&cat=&page=1
Obviously the best for the job will vary depending on power, but which would represent the best value for money in terms of "flow potential" per dollar or value for money etc?
Discuss... (hopefully this could become somewhat of a reference/review thread)
https://www.sau.com.au/forums/topic/428278-cat-converter-upgrade/
Xforce - $156 pp http://www.ebay.com....d4d681fb&_uhb=1 Had one, rubbish restrictive once it's hot
Venom 4" - $250 pp http://www.ebay.com....7fbb1c7b&_uhb=1 Both my mates have them, great quality. Core is welded in place too
Venom 5" - $300 pp http://www.ebay.com....d0354ae5&_uhb=1 A few of the boys here use/used them (I'm waiting for George to get back to Australia and making a custom 3.5" In/Out with the same body)
Catco Highflow - $175 pp http://justjap.com/s...066&cat=&page=1 Had one, it collasped on me
Catco Metal Racing - $379 pp http://justjap.com/s...441&cat=&page=1 Never used, no idea.
i was recently quoted $12 for a broom stick from bunnings,
unbolt cat
smash it out
high flow
don't get around the fact that it steps down to 2.5 inch, so there is still a restriction
and the potential for a big epa fine
and further discolouration of by rear bar
Sounds good, pretty much what i wanted to know
Might go the 5" body Venom to be on the safe side
George (Venom owner/worker) did say the 4" body will flow easily 250kWs, but if you're shooting fo over 300kW the 5" body will do.
Just to put things into perspective, look at the Catco range, their cats are much smaller, same cell count but they claim over 300kW easily, so look at Venom cats, they could be under rating them.
I'm just a little anal, so I'm asking for a custom one to be made up for me (totes overkill lol)
I have a 5in 100 cell from Venom - putting 308awkw through it atm
Yep i have a 5in 100 cell from Venom putting 390ish kw through it! Well in saying that the gate is doing a lot of work BUT still it flows well!
George was really good to work with! Great guy and went out of his way to help me when i was on a deadline!
out of interest what is the fine for doing this?
So are you saying that running E85 and no cat is legal?
:no: lol
You get caught with no cat and you are in trouble!!!
Hey Guys
So options are:
I have purchased a Catco Metal Racing - $379 pp that will go on my build to begin with. If I cannot get the results I want with it I will replace with a Venom 5" body 100 cell cat as I have heard good things about it.
from memory $1000 per cyl +get
But e85 is carbon neutral so you don't need a cat I think
Cat converters and carbon neutrality have nothing to do with each other. All road vehicles that comply with the ADRs MUST have a functioning cat converter fitted. There is no way around it.
that is what I thought too.
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
