have just serviced it.
so will keep an eye out.
How quick is to quick to see some back in there? bearing in mind its only the smallest amount. its like just a bit of scum up the top when i serviced it after a bit over 5000kms>?
This is a very common issue with metal head gaskets when they have been installed dry (no hylomar spray), or if the head and block weren't surfaced exactly dead flat.
Provided your not leaking combustion gasses this is easy to fix.
Get yourself a cheap ass ebay radiator or an old second hand one. Fill the coolant system with water, bleed the air and go for a drive to get it up to temp.
Shut it down, and VERY CAREFULLY with a very big towel or rag, take the radiator cap off. Give the top radiator hose a few squeezes to get rid of some of the water.
Start the car and then empty a bottle of BAR'S Stop Leak (Cooling system sealer) into the radiator. (Lots of auto shops stock this stuff) Top up with water and put on your cap.
Drive the car like this for about 2-4 weeks. Then drain the water, flush the system through a couple more times with water (running it up to temp each time).
Last of all, swap back in your good radiator and fill with coolant.
As a precaution, it would be worthwhile having all your head studs torque settings checked too. This is a cam covers off only job, and is perhaps an hours work at most for a good mechanic. This is an overkill check though, as if something was loose you'd have nothing but combustion gas in your radiator. Not just a little oil.
Ah thats makes a bit of sense actually.
I ran my tuner, who also did the engine rebuild and he said he would be shocked if it had done the gasket or cracked a head etc.
He to said along the lines of when the gasket was installed there may have been something wrong etc. and they will check it out no charge for me and go from there
Just an update.
Just got the car back yesturday.
All checked out fine.
Head was tested along with the head gasket both fine.
Had a compression test, come out excellent.
The cooler was leaking slightly but leaking oil OUT not in, but that has been fixed.
The little scum / oily film has been mainly put down to it being a new motor and during the rebuild may have got some in there along the lines.
So all in all, its all good. Flushed the radiator etc out for me to and topped up with coolent no charge, long story short im a happy man!
Just an update.
good thing the hg wasnt changed for no good reason eh?
glad its worked out cheaply for you too
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
