Hi guys,
Links are becoming broken if they include certain (valid) characters...
eg.
http://en.wikipedia.org/wiki/Howl's_Moving_Castle_(film)
Is there any way we can modify the function that auto generates the anchor tags to allow for links like this?
Cheers,
Simon
https://www.sau.com.au/forums/topic/428330-links-become-broken/
A quote/apostrophe is not a valid url character and should be encoded. The search results on Wikipedia now have an encoded version of this link (I'm assuming somebody else noticed.)
Encoded it looks like this;
http://en.wikipedia.org/wiki/Howl%27s_Moving_Castle_(film)
But, if you really want to have the whole thing link, then paste it, highlight it and click the link button in the WYSIWYG editor. It can't auto link that because it see's the apostrophe as a break.
Hope that helps?
I was pretty sure that an apostrophe is valid, even unencoded... Not a major issue obviously, I've just seen quite a few posts with broken links which aren't getting "special characters" automatically encoded by the Editors linking tool and then people in following posts saying "Dead Link"
http://www.ietf.org/rfc/rfc1738.txt
bottom half of Section 2.2...
hus, only alphanumerics, the special characters "$-_.+!*'(),", and
reserved characters used for their reserved purposes may be used
unencoded within a URL.
Holy smokes. There you go!
Thanks for that. The problem with the quotes, both single and double, is when used unencoded, they will break 'a' tags...
ie;
<a href="http://mysite.com/check_out_this_"cool"_site"> - that becomes a link to http://mysite.com/check_out_this_
That is what is broken when you rely on the auto linking.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
