Hey guys
My mate wants to sell his 1995 R33 GTST S1 it's got ABS
POD FILTER
XFORCE EXHAUST (3" turbo back)
NISMO CLUSTER
17x 9.5 all round WRAPPED IN PIRELLI P-ZERO
GTR STYLE FROUNT GRILL
ALPINE HEAD UNIT AND AMP
BATTRY HAS BEEN MOVED TO THE BOOT
DUCK TAIL STYLE SPOILER
GTR STYLE SIDE SKIRTS
The diff and cradle bushes has been done recently.He is after 6500 ONO
If any1 is intreated please PM me
Thank you
https://www.sau.com.au/forums/topic/428338-1995-r33-gtst-s1-for-sale/
  • 1 month later...
  • 8 months later...
Yes, even though it's been a while have some old pics and will get some new ones.
Since the Ad was posted a few things have been changed:
Both front hubs have been replaced including bushes etc.
Have spare turbo (ready to be High flowed or just to replace the current one)
Spitfire coil packs
Diff has been replaced with a 4.1 Ratio diff from an Auto 33
Nardi steering wheel
HKB boss kit
Driftworks quick release kit
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
