Hi Guys,
we carry a huge range of brand new Work Emotion Kiwami in stock
Any set of 18 x 9.5" in Bronze, Matte Black or White is $1800 for a set of 4
http://www.importmonster.com.au/shop/product_info.php?products_id=1758
Any set of 18 x 10.5" in Bronze, Matte Black or White is $1850 for a set of 4
http://www.importmonster.com.au/shop/product_info.php?products_id=1759
Set of 4 265/35/18 Yokohama AD08 is $1520 fitted and balanced
Package any set of rims above with a set of 265/35/18 Yokohama AD08 tyres and take $100 off the total.
18 x 10.5" for $1850
Advans $1520
= $3370
$3270 after $100 package discount.
The stocks of AD08s are very limited, I pretty much bought out the last of the remaining stock before they move to the AD08-R - which won't be available for 6-8 weeks (and will be about $100 a tyre dearer than these)
Cheers
Aaron
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
