Sau Nsw Tech Night: Suspension & Steering @ Heasman 06/09/13
Bad luck with the timing of this night as it clashes with my daughter's birthday so we will not be attending.
Clinton and I have been to a tech night at Heasman's in the past and it was very informative. One of our GTS-T's would have been a good demo car as has Bilstein PSS9 coil overs from a GTR all round. It runs modified top mounting plates in the front and a full GTR rear end.
Looks like no more execs coming, in this case, 2 more spots have opened up for members :)
happy to come along too!!! =D count me in, even though it looks like numbers are full =S
You're now in!
  • Like 1
Yup, certainly worth joining Robert since we have another Tech Night coming up in spring!
...+ more next year :)
Thanks guys will follow up -I saw the JEM wrapup thread recently, looks like you guys run some good events.
So procedure is sign up and then keep an eye out for coming events?
Is this one full already? I was planning to get an alignment and corner balance done at Heasman's at some stage so I'd be interested in checking them out if there are spots available. Sorry if it has been explained above I've done my best to sort through the posts...
Yep, a Z32 for the last spot, number 32 :ph34r:
Join up and this this will be your first of many great tech nights coming up!
You're now in!
MAD!!!!!!! =)
Cheers Ricky!!!!!
Cant wait now!!!! =) ill be there with bells on!!! =P
Join up today Robert as there may be a spot left.
And even if a Reserve List is formed, most of the time it shrinks as the Tech Night looms closer :)
Cheers guys have just paid membership and emailed the paperwork to Shell
Thanks I am wondering what is happening too? My last communication with shell was 13/8
you're already been done on the website - (blue box under your image)
The behind the scene business takes a bit, but be sure you've had great success in joining.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
