hey lads i have a r33 gtst that was running perfectly fine saturday and now blows alot of black smoke in idle on sunday
thinking it could be the MAF/air flow sensor ?
what voltages should the stock r33 airflow meter read at idle and wot and any help with colour code on the air flow would be great thanks
https://www.sau.com.au/forums/topic/428355-r33-blowing-black-smoke-at-idle/
How old is your turbo?
Pull your intake pipe off and see if there is any oil in the front housing. Could be turbo seals.
Car will still boost and drive fine, will just blow some smoke at idle and decel.
Could be something else so eliminate all possibilities.
Lots of black smoke indicates excessive fuelling issue. All systems governing air/fuel mixture to be checked including OP's AFM as he has already suggested. Turbo seals blow white smoke.
Sorry have a z32 with Apexi PFC, so don't think giving you the readings would help. Let me know if you really want them.
If car was running fine Saturday, was there anything that had changed or become different since you last drove it?
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
