Hey guys! Recently my Skyline got written off in a car crash and just a day before my Splitfire coilpacks arrived in the mail so I didn't get a chance to put them into the car due to the crash. They're absolutely 100% unused, I haven't even opened the box yet. For those interested, make sure you check that these are compatible with your engine, they're suitable for the series 2 RB25 engine. Series 1 and 2 have different ignition systems do you don't want to get this wrong. I'm looking for $400 for them and I'm located in the Liverpool area in Sydney, NSW. Thanks everyone :)
dis-008 is for neo motors according to the ones for sale on justjap's website
The neo engine is the series 2 engine, just different terms although neo is the official one used by Nissan
Neo and series 2 are different. Series 1 R33 uses DIS-001, series 2 R33 uses DIS-005, and NEO uses DIS-008. Don't call NEO series 2 as you will just get everyone confused as no-one else refers to a NEO as series 2. :thumbsup:
So just confirming you have DIS-008 that will fit RB25 Neo (R34)?
Yep that's the engine I had
edit: sorry I didn't realise Neo and series 2 were different.
Edited by Kieren
  • 1 month later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
