hey guys, just wondering which turbo is bigger? vl turbos came out with steel wheels didnt they? if i was going to do the mod boostd done would the vl exhaust housing be better or is smaller? how is compared to the vg30? the vl one isnt ball bearing is it? sorry for all the questions just wondering which would be the better base for the upgrade.
https://www.sau.com.au/forums/topic/42840-vl-rb25-vg30-turbos/
ive got a hybrid turbo allready made up for sale
Specs are
RX7 hitachi core and rear blade cropped (full steal)
Fully machined into a VG30 .71 AR rear housing
Fully rebuilt with new oversize bearings
T4 6.0 A/R front with waste gate actuator
Dump pipe to go with it. Turbo has done 2000k's and only had 10psi run through it.
0412 417 579 gemme a call
If you use another turbo with a steel turbine wheel, the increase in rotating mass will require a smaller exhaust outlet size for similar boost response. This will directly cause increased restriction and power loss. Would probably be a better option on a 3ltr however. as my turbo would almost certainly boost to early and surge due to increase capacity.
Also different A/R exhuast's will cause a change in spoolup time which will need to be compensated for at the turbine side.
Big can of worms... that why it is so much simpler to go with a proven setup. I had 7 goes at mine. HKS on the other hand.......well you get what you pay for.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
