Hey all, got a few knocks and what not in the rear end of my R34 Gtt sedan. I knew that one of the coilovers was on its way out.
So the report back was that I have outer tie rod end play. Whats the best option for resolving this, they quoted me 340 to fix that. What parts are needed in that, worth going aftermarket or what?
Also they came back saying there is a rattle and play in the rear rack end. With this, can this be solved with a lock bar or do I have to replace the item. Got quoted 840.
Also is there any decent places in Eastern Melbourne (ftg) that don't charge through the teeth to work on this. As they also quote 360 just to put coilovers that I supply in.
Any help is much appreciated and thanks.
https://www.sau.com.au/forums/topic/428414-r34-rear-end-queries/
It would be if I knew something about the rear end and know what I could solve the issue with.
Maybe instead of just posting usless stuff like that, have a useful input.
On your theroy 90% threads should be searchable but still get started.
Dan thanks for the response mate
above is right, you could have searched those keywords (isn't that how you normally search??)
but to give you a start, nissan can order in new HICAS tie rods (rack ends is a different name for the same thing, i believe). and the HICAS tie rods are different to the front tie rods (obviously) so don't go buying cheapo ones off ebay.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
