Has anyone heard of, or been, fined as a result of an excessive reading at the track?
Read a ruling in some recent supp regs indicating it's possible/likely. :angry:
What is the fine for exceeding noise limits?
I reckon that on public roads they should give you a second chance to remedy it and then just send you home anyway.
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/
You don't get fined for a reading over 75DB, you just get sent home. Makes it an awful waste of money to get to the track, knowing your car could be over the limit to get sent home. The noise limit's are strictly enforced, and because they are so well known, ignorance is no excuse. A track is NOT a public road, it is a private venue available for hire. Not only do you waste your money, you make it hard for everybody else and for the club holding the event by taking your over limit car to one of these events and trying to get away with it.
It's just way easier to make sure your car is under 75db at 30 metres.
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-6922570
I heard someone last week or the one b4 claim to be fined for excessive noise at Sandown last weekend or the one b4.
turned out when dug deeper he got busted leaving sandown on the street and busted by EPA
AFAIK we are on private property when on a track so we cannot be financially fined, just removed from the track
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-6922638
I can confirm 100% without a shadow of a doubt at Sandown you do not receive a fine.
You get warned if you are over 75dba and given a chance to reduce the noise output. If you go out again and you are still over, then you get sent on your merry way :)
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-6923141
Hmm. The sup regs for the upcoming John Mott Memorial Sandown mentions you may get fined for being over the noise limit.
http://www.nissancarclub.org.au/Events/Downloads/2013JohnMottMemorialSprint2013/John%20Mott%20Memorial%20Sprint%20REGS%202013.PDF
Blue text halfway down
I'm entering anyway so I'll make sure I'm only 74.98dba :rolleyes:
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-6923913
^ lol exactly, everyone has been doing that for years - and that's even if a tester rocks up (not always)... If they do, they usually set up in the same spots each time, so it's not hard to work out.
Also once the dude has gone home (rarely there the entire day at a club sprint)... Well... You know what to do :thumbsup:
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-6925358
  • 2 months later...
Yup, no guilt in doing this either... In 95% of cases the race tracks were there before the houses that complain.
It's no different to building next to a major airport and complaining and in my opinion should be treated as such. i.e. houses should simply be told bad luck.
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-7025991
  • 4 weeks later...
I should re-word my question.
Is the 75db limit in the supp regs correct? or is it possible that it has just been carried over from other events in the regs?
just curious because its the first time ive personally come across 75db for winton
https://www.sau.com.au/forums/topic/428420-noise-at-tracks/#findComment-7067934
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
