Hey all.
I need to know where YOU have your boost gauge vacuum line connected to on YOUR rb20det.
I have read heaps of different things on the interwebz so please don t just tell me to google it.
mine is connected at the back of the plenum. But i do not think i am getting the right reading. Which is why i want to know where YOURS is tapped into.
Also, do i need to run the boost line to the little black box that is stock with the rb20det or can i just go straight to the plenum ?
https://www.sau.com.au/forums/topic/428428-boost-reference/
Ok answer me this.
I have no bov so I have "dose". I know that you can have the dose sound while not being in positive pressure. Like the boost gauge not hitting zero yet.
Because I have a t04e it takes ages to get boost. But shouldn my gauge read zero with just my foot flat even if the turbo is not making boost? I ask coz atm I rarely see it go past zero. But at the same time, at wot it slowly climbs to zero and I hardly see it there either
Sorry if this is confusing, I cant think of the best way to describe it
https://www.sau.com.au/forums/topic/428428-boost-reference/#findComment-6924134
"Dose" is air bouncing off the compressor blades when you close the throttle valve. As long as the turbo is spinning air > shut throttle > air goes back onto the compressor > pigeon noises
WOT should read 0 vacuum. So yeah, you have some problems somewhere. On my car, standard gauge sits just above 0 while the engine is trying to spin past 2,000rpm (don't need WOT for it to that).
https://www.sau.com.au/forums/topic/428428-boost-reference/#findComment-6924302
