im building a custom car with a r33 GTR powertrain and a full built rb26 check out my other 2 threads to see what im building and spec. My question is how should i go about building a very strong drive line. Im planning on a exedy twin clutch, all axles and drive shaft are custom built buy driveshaft.com and can handle more power then ill ever have. the rear diff is a stock r32 gtr lsd ill have the LSD rebuilt. the front diff is stock and ill be puting in a LSD. Now the center diff how strong is it ? is there a up grade kit or something that im not aware of? and the transmission i heard that 3rd gear is weak so is there a trany upgrade kit to fix this or do i just have to bit the bullet and buy a race trans like OS Giken? I do have a great transmission builder so a up grade would be no problem. Ill just be smooth on the powertrain till its fully upgraded but i want to be able to run it hard on the track with slick mainly race track but some drag racing. any help or advice with this would be great and if there are some treads i have not read please sent me links Thanks
https://www.sau.com.au/forums/topic/428442-bomb-proofing-gtr-powertrain/
Am I missing something?
GTR's don't run a centre diff unless you're building a special transfer case using parts from some constant 4WD?
That's the thing... They don't, as you know. :D
Always helps to know the basic mechanics of the car you are building before you go asking for quotes.. I'm sure any workshop would be happy to charge for a 'centre diff' and the send you some metal in a box.
WOW really.....ok fine a transfer case ,ATESSA just abbreviating
Edited by saulogy
Try this, google the difference between a centre diff and a transfer case. These guys know the car mate, it's clear your mechanical knowledge is a little way behind theirs. As for "bomb proofing" a gtr powertrain, put at least 40k aside. That's if you want to really do it properly. Lonefield billet cv's, billet driveshafts, carbon props hafts, hollinger sequential gearbox, quaife diffs front and rear, gts4 crown wheel and pinions, modified sump and front diff housing. Then you need to look at clutches, it gets out of control as while you make one thing stronger it creates another weak link in the chain.
There is GENUINELY bomb proofing as you say, then there is sensible strengthening of components
if $$$ is not a problem sure knock yourself out but if $$$ is not infinite, then maybe u should plan on reasonable upgrades. Why pay for a part that can take 2000hp when u will only ever have 1000hp unless of course the price is the same then by all means.
u can make a car fast and reliable without spending exorbitant amounts of $$... :)
Pretty big difference between a transfer case and a diff!
To do it on the cheap, properly, you're still looking at least 12k in diffs, clutch, transfer case, gearbox.
That's not taking into account axles, driveshaft or anything else.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
