im building a custom car with a r33 GTR powertrain and a full built rb26 check out my other 2 threads to see what im building and spec. My question is how should i go about building a very strong drive line. Im planning on a exedy twin clutch, all axles and drive shaft are custom built buy driveshaft.com and can handle more power then ill ever have. the rear diff is a stock r32 gtr lsd ill have the LSD rebuilt. the front diff is stock and ill be puting in a LSD. Now the center diff how strong is it ? is there a up grade kit or something that im not aware of? and the transmission i heard that 3rd gear is weak so is there a trany upgrade kit to fix this or do i just have to bit the bullet and buy a race trans like OS Giken? I do have a great transmission builder so a up grade would be no problem. Ill just be smooth on the powertrain till its fully upgraded but i want to be able to run it hard on the track with slick mainly race track but some drag racing. any help or advice with this would be great and if there are some treads i have not read please sent me links Thanks
https://www.sau.com.au/forums/topic/428442-bomb-proofing-gtr-powertrain/
Am I missing something?
GTR's don't run a centre diff unless you're building a special transfer case using parts from some constant 4WD?
That's the thing... They don't, as you know. :D
Always helps to know the basic mechanics of the car you are building before you go asking for quotes.. I'm sure any workshop would be happy to charge for a 'centre diff' and the send you some metal in a box.
WOW really.....ok fine a transfer case ,ATESSA just abbreviating
Edited by saulogy
Try this, google the difference between a centre diff and a transfer case. These guys know the car mate, it's clear your mechanical knowledge is a little way behind theirs. As for "bomb proofing" a gtr powertrain, put at least 40k aside. That's if you want to really do it properly. Lonefield billet cv's, billet driveshafts, carbon props hafts, hollinger sequential gearbox, quaife diffs front and rear, gts4 crown wheel and pinions, modified sump and front diff housing. Then you need to look at clutches, it gets out of control as while you make one thing stronger it creates another weak link in the chain.
There is GENUINELY bomb proofing as you say, then there is sensible strengthening of components
if $$$ is not a problem sure knock yourself out but if $$$ is not infinite, then maybe u should plan on reasonable upgrades. Why pay for a part that can take 2000hp when u will only ever have 1000hp unless of course the price is the same then by all means.
u can make a car fast and reliable without spending exorbitant amounts of $$... :)
Pretty big difference between a transfer case and a diff!
To do it on the cheap, properly, you're still looking at least 12k in diffs, clutch, transfer case, gearbox.
That's not taking into account axles, driveshaft or anything else.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
