Hi Guys
So recently my car has started making a ticking noise under boost. When I rev it neutral or just idling, its all good but when there's load on the engine(under boost) the ticking becomes louder.
Is this a symptom of the common cracked exhaust manifold stud on the 33 or something more ominous like the turbo failing?
No classic signs of turbo failure like white smoke or whistling sounds.
Car also pulls as hard as ever , no effect on performance.
Thanks in advance
il add that im running an hdi electronic boost controller..
which hasnt worked for about 6 weeks(gauge only goes up to 1psi when it clearly is boosting more then that.my controller does nothing either ...turning the knobs neither increase nor decrease boost.
A ticking noise under boost generally means a flapping gasket (either busted manifold stud or lose bolt). Simple to look for. Check all the manifold studs are still intact.
I'd also be looking for the cause of boost controller issue.
Usually an exhaust leak will be more pronounced when the engine is cold, and be audible under most conditions. The duty cycle solenoid, however, points to the root cause of both of the aforementioned problems.
I would say busted gasket that sits between turbo and manifold. You should be able to pinpoint the source of the noise pretty easily.
possibly.ive also noticed i can really hear the exhaust from the engine(like a motorcycle ).definitely something going on there
padens having a look on the 26th.will stay of boost until then
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
