ITEM: RB25DET
Up for sale is my brothers New/Never started rb25
Professionally assembled
​Specs are as follows of the top of my head
Camtech spring retainers and locks to suit cam specs.
Speedflow oil return fitted rear
ARP studs and bolts throughout motor
Cometic mls head gasket
Kelford cams (unsure of spec atm - large)
Rollmaster Adj cam gears
Gates racing belt tensioner kit
Cp Pistons
Spool I beam Rods
Greddy Copy plenum with 90mm t/b
Billet fuel rail with 870cc Siemens injector’s n 1200 turbo smart fuel reg
Turbosmart Gt3582r BB on 6 boost mani 50mm T/smart pro gate with screamer
N1 Oil pump Powermax Water pump
Excedy triple brass buttom clutch for R33 5speed
4140 Chromoly stell lightened flywheel rated 1000hp
SPOOL high volume baffled sump
Ross metal jacket balancer
Motor was assembled by CRD with receipt. Change of build plans motor is for sale
CONDITION: NEW
PRICE: $12,000
CONTACT: DAVE SMS 0421 719 154 any enquires or for pictures.
https://www.sau.com.au/forums/topic/428456-nsw-700-800hp-rb25-motor-new/
    • Holy hell! That is absolutely stunning! Great work!!!
