Hi all,
Was guna put this in forced induction section but preferred to speak with all the local guru's about this.
Just landed a gtr 33 v-spec and fuel pump was workin in Japan but not now in oz?? There is power to the pump but no go.
Could I get some advice on price to replace the standard in tank pump or down the track when chasing more horsies , would I be better to get a good aftermarket one done now and what other stuff would I need like regulators? AFM?programable ecu? etc if I go down the track of aftermarket stuff as everything else is standard with the gtr. Guna talk to Richard at all star when I get a chance but previous experience and input from others would also be greatful!!
Thanks
Edited by smidy
https://www.sau.com.au/forums/topic/428461-gtr-33-fuel-pump-suggestions/
Just put an aftermarket pump in it now. Decide which one by how much horsepower you'll be after in the future.
You won't need to change anything to fit it. Maybe a few small mods to get it to fit in the cradle but that's it.
old days people use bosch in tank pump, as long as you can get fuel pump to sits in the bracket and connects to both fuel hoses.
see pics of original fuel pump+bracket:
http://www.gtr.co.uk/forum/134596-photo-sock-orientation-r33-fuel-pump-needed-please.html
if you are cheap and going with walbro pump, you might need to do 14v re-wiring for safety.
Edited by japtaxi
I went with walbro pump but only 255l/hr does this need rewiring??
Have been told it is just a straight swap no rewiring or modifying in tank brackets ?
walbro 255 supports 12V
bosch 044 is not an intank pump. its external and is bloody noisy.
for most apps, walbro 255 is enough. get 2 if u need :D then u'll need a surge tank. Sard's 2L one is really pretty and neat. just make sure u add/replace the gasket that they give u. after that u might wanna look at an aftermarket fuel rail and fuel lines... crimped connectors with kevlar lines, aeroquip or earls
Great thanks m8, bit clueless to tech specs and haven't even seen the pump as car still gettin complied and I'm 1000km away at work! just tryin to do me best to organise it on a phone!
Yeah plenty of ideas of modifications to come in the future that's for sure, at this stage just wana get behind tha wheel and enjoy...
pretty old info about voltage and flowrate, may/may not apply to newer fuel pump.
http://www.stealth316.com/2-fuelpumpguide.htm
common bosch installs are to put the 040 intank...
Note: this is not my image, just pinched it for illustration purposes...
please dont use zip ties, although probably effective you'd be much better going with some pipe clamps...
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
