If I remember correctly there was a nismo version of this thing.
where do I find it and in what country?
otherwise I need to find a OEM one.
working on a project for the R31 and this may be 'easier' to adapt into what I want vs a HKS camp piece.
start of it looks like this:
933890_10201614251941361_2107581837_n.jp
that is the tach panel out of a spare dash I have.
the idea is to mod the R34 item and stash the guts under the seat and shrink the screen a fraction so it fits in that area.
https://www.sau.com.au/forums/topic/428475-r34-mfd/
I've seen an R34 MFD in an R31 before. Guy in Melbourne had one wired to his RB25 NEO - you may know the car, it was a coupe, very unique green colour on 5stud te37s.
I think the nismo version was just the software was different?
https://www.sau.com.au/forums/topic/428475-r34-mfd/#findComment-6923957
not really fussed on version. after I posted this I went looking and realized that the nizmo one is a board upgrade. I need the whole thing as I am going to cut it up and change the screen.
the end result will be a joystick at hands reach and a screen in the dash.
https://www.sau.com.au/forums/topic/428475-r34-mfd/#findComment-6923960
think u can only get it from japan. comes in english though i think. best bet would be to email nismo jp or ask one of those internet company that sells car stuff... they might be able to import for u from japan.
the nismo mfd comes with a board replacement and some sensors i believe.
https://www.sau.com.au/forums/topic/428475-r34-mfd/#findComment-6924595
spoke to a mate of mine in osaka this morn. used for the OEM they command silly money anyway. looks like I am going that route. won't be for a bit though as I need to get a few other things under wraps first.
https://www.sau.com.au/forums/topic/428475-r34-mfd/#findComment-6924760
  • 8 months later...
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
