Just finished fitting. No issues, 15 minutes of my time. Feels good man.attachicon.gif20140711_104811.jpg
If you are under the bonnet as often as i am then maybe put the plates on the outside of the bonnet hinge... May not look as good but will retain the factory bonnet strength...
I noticed on the diagram they have it on the outside, and I notice NYTSKY had them on the inside. Wasn't sure what way to go and didn't want it protruding. Will re-arrange later. Cheers.
Edited by sleptema
I had it on the inside as per the pic on the first page but now have a bent bonnet... This is not due to anything wrong with the struts, just caused a weak spot in the bonnet after being lifted so many times, for most people they wont have an issue :)
  • 1 month later...
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
